Suggestions for driver selection
shubhendu_pal
Kolkata
Hi everybody, planning a 3 way bookself. I dont want earth shattering bass, so no subwoofer. My plan is to use a 5 inch woofer, 3 inch full range, as i already own it, and 3/4 inch tweeter driven by 2nd order crossover and tpa 3118 class D amp.
Earlier thought of a single driver system, so TC8FD05-04 - 3" Paper Cone Full Range is purchased. Now, i am going to purchase SB Accoustics SB13PFCR25-4 5'' Paper Cone Woofer and Dayton Audio - TD20F-4 - 3/4" Soft Dome Neodymium Tweeter 4 Ohm.
Are they ok for my project? Or i should go for Dayton Audio - ND140- 4 - 5-1/4" Aluminum Cone Midbass Driver 4 Ohm? How about Peerless Fabrikkerne (I) Ltd - TL25AN - Aluminum Dome Tweeter? Pdf specs are attached for my choices, TL25AN had no pdf, being Indian make.
Tight on budget, so not considering higher priced tweeters. Peerless Fabrikkerne is Indian brand and read they are not upto standard, not sure though, but goes upto 1.5khz.
Preferring sealed enclosure as small as possible. So dedicating woofer to its duty and FR for high bass and mid. Thats why 3 way is considered. Am i wrong? Thanks in advance.
SB Accoustic one had pdf size bigger than that can be posted here. May i sincerely request you to go audiofy.in product page and get it.
Please be careful while posting threads, especially the titles. Misspelled words in titles look particularly awful. I've corrected two spelling mistakes in the title.
