sapphire903
Dear All,
This is a very exciting forum, I was looking to buy an HTIB earlier but after reading a lot of posts on this site, I have decided to go ahead with building my own system and I can add on whenever I need to. I have gone through a lot of posts but havent been able progress much.
I will be using it for Movies / TV and listening to music, you can say it would be about 60:40 - and in the living room only (atleast as of now).
- Movies will be played through laptop through HDMI port, TV is already Full HD capable. (suggestions on a good media player is good too)
-Music will be played through USB / Laptop and in the longer run iPOD.
I had started my budget at about 25K or so, but I am willing to go upto 50K, as if I have to build, I might have to spend in that range.
Overall Room Dimensions - 12 Ft X 20 Ft
Actual area used for watching TV/Movies ~12 X 12
I'd like to buy something that covers me for the future advances in technology (atleast the ones we know of, 3D, Blu Ray etc)
I need the suggestions on the following
- What can the ideal power output I should look at (if I am listening to music, I may want the music to be audible to rest of the flat)
- How do I match the receiver + speaker
- Do I invest in 7.2 or 5.1 is good enough
- Any suggestions on media player compatibility (like Seagate, WD - as I have a lot of downloaded HD movies and music - mp3) with receivers
- Any tips and what I should be critically looking at?
- Any audiophiles from Mumbai can suggest where to get these things (if there are "right" places other than Croma, VS.
I have a Sony Bravia 40 inches and a Nintendo Wii
I was looking at various Onkyo's (notably 3300, 307/308), Denon (1911, 1610), Yamaha HT, after looking at them at croma (292, 392). However, I had no clue on how to build the speaker / woofer systems and which companies to go for.
Sorry its a long post, and I may still have missed something.
Looking forward to your help.
