Support Required!
hafiz101
cochin
Hi, Recently i bought a Onkyo HT R390 audio system. Now the rear right speaker is making unwanted noises. At the time of installation installer told me to change the speaker cable to improve the performance. Whether the speaker cable is reason behind the noise or do i need change that speaker itself?
PLS ADVICE ME..
Speaker cables do mischiefs.You can test them with thick cables(even short one for test)& then get a wire bundle.
Swap the rear speakers. I.e. use right speaker in left and vice versa.
Does that speaker still has issue?
Thank you all for the kind response. Onkyo service person have agreed to come tomorrow for physical verification. Will update you the progress after that
