[Tata sky] any way of identifying your dish antenna?!
TheSeeker
Thane/Mumbai
hello!
is there any way of identifying (by a user), which dish antenna belongs to your STB/connection, among a myriad of other antennae? serial no., or anything else? cable-tracing is very tough.
also, does upgrading from TS SD to TS+ HD require a new dish antenna? i suppose not.
It will not require a new dish antenna but you would end up with two wires from the dish ideally.
No, there's usually nothing on the dish. I suggest you add some identification paint/sticker on your dish.
You don't need to change dish for HD+ upgrade. You will have 2 cables from the dish to your receiver.
No need to change your dish or LNB to upgrade to HD.......put a unique logo to identify your dish....
thanks for the replies everyone!
actually, upon not receiving signal for 2-3 days, had called a technician to check. after tracing cables for sometime, he came to the conclusion that our dish had been removed. i didn't know where the dish had been. he had traced a disconnected cable lying on the terrace, and connected it to his instrument, and synced it with my STB to check if the cable was from my dish, and the instrument responded to my switching the STB ON & OFF. he then took a new LNB that he had with him, connected it and the cable to an unused dish on the terrace, so for now, thats working for me.
later on, my brother came home, who knew where our dish had been placed, and he pointed me to the location, which is different from where the technician had told our dish had been and was apparently stolen/misplaced. but my brother didn't know which dish out of the several now installed there had been ours, as at the time of installation, ours was the only dish there. am going to call the technician tomorrow and seek a clarification. its a little complicated to describe it all here. will anyway post an update here.
and yes, marking the dish in big letters & numbers with PAINT is very important, as i learnt now!
could anyone please tell me, what would it cost for getting a new LNB installed to the dish, through official means, ie, by sourcing it & getting it installed officially from a TS technician?
