Time to upgrade from Wharfdale
ankitbhargava
Udaipur
Have gathered courage to spend on the upgrade, planning to get a new Speakers.
100% usage will be Movies
Budget 1-1.25 lakh
Need to buy 5.0
Not changing Sub woofer
I like good punchy sound but not fabricated one
suggestions please :)
IMHO there is hardly any other speaker brand as VFM as HSU Research. See if they're available through any dealer in india
The RTI series according to Profx need good amount of power to sing, so please check power specs on your receiver before pulling the trigger. You may want to talk to the profx folks before deciding - they know polks best
Marantz 6009, whats your opinion?
Budget 1-1.25 lakh
Need to buy 5.0
When you have 100% usage for movies, consider BS speaker (or) a high end satellite speaker system.... A FS doesn't add anything to movies, once it is calibrated, crossover kicks in & sets it @ 80Hz.. So the purpose of FS is defeated....
Since you have a good room dimensions of 16 x 14 and a 7.2 capable AVR, you can consider getting 7.0 speakers than settling for a 5.0 FS system...
You may consider Sonodyne Avant LCR 250 speaker x 7 pieces.... The advantage is that all the 7 speakers are timbre matched..
BTW my brother uses Avant LCR250 as fronts in his HT system (Left, center, right)....
Thanks guys
Back of my mind I am also working on a possibility of selling off my newly done Stereo setup (Q Acoustics 2020i + Cambride Audio Minx) if I buy a capable 5.0 or 5.1 setup.
For example SVS Prime Towers + Center + Satellite and replace my Velodyne Sub with a PB 1000 sub?
OR
Polk RTi A7 suggested combo with a PB 1000?
Another possibility is to keep Stereo as it is
buy SVS Bookshelves + center + Satellites and invest into a PB 2000
all advise much appreciated
Thanks for valuable suggestion!
Just struggling over space and content for a 7.1 at this moment
probably next year I will plan a dedicated HT Room and would love to go on a proper Atmos meantime we would see the content availability also.
Being from a small town, things are little different :)
ankit sir, u already have Q acoustics 2020i as stereo , buy a center channel for that and try if u like that sound then u can move for another pair and make it as 5.1 :)
Have tried that already but with the existing center of Wharfedale :)
It wasnt impressive, obviously the center has been playing main role
Buying a Center for experiment would be little too much :D , have already spent a lot on the gadgets an you know how rules of a married house work.
But please keep the suggestions coming in ..
well there are specific posts related to Dali in this forum. you can search a bit. I think Dali 5 or 7 for fronts (if music & movies) or Dali zensor 3 (for movies) is what I could see the desired likes here
Your room is good enough for 7.1 or probably more... My room is 14 x 11 feet and am doing a 9.0 system currently..
With existing 5.1 movie tracks, surround expansion modes such as Dolby ProLogic IIz, DTS Neo X and Audyssey DSX extract information from the existing soundtrack and expand the sound-stage accordingly.... Have used all 3 of them and quite happy.....
Anyways up to you to pick what suits your needs and limitations...
will 100% consider it!
infact I will have spare speakers to atleast try out
Thanks so much for your valuable suggestion sir
