UPGRADED TO FOUR SUBS - Still Chasing Perfect Bass
I've run miniDSP calibrations to flatten my bass response, but I'm only getting good bass at my MLP. The problem is that other primary seating areas are still plagued by nulls and a distinct lack of bass, despite having four powerful subwoofers that I know are capable of filling the room and addressing these dips. What more concenring is that even at MLP I am not getting that powerful chest punch like performance and it feels underpower :(
You can try multi sub optimiser software too. Since the sub is tuned for extension, I doubt it can produce great midbass.
Yes, you have to. Why did not you buy 2 pb 2000 pro
When I purchased my setup back in 2022, the dealer had the PB1000Pro available in stock. After demoing it, I finalised the purchase. I wanted to ensure that all the subs in the system should be the same models, when adding two more.
Have you tried the OCA Room correction tool for Denon/Marantz system. If not, you should give the latest version of his free software a try.
Not yet, could you share the guide or tutorial?
There is a catch in this. Do you have treated room like the demo guy had?
Hmm, Interesting, I need to arrange a Windows Laptop for that. Does OCA Room correction tool works differently than the Audyssey ?
I used the Audyssey MultiEQ app for the measurements. Then pass the measurements on to my Mac. Following which I run the OCA software and REW on Mac and transfer the filters back to the receiver over the air directly from my macbook.
if you dont have the Audyssey MultiEQ app, then the process of taking measurements using REW can also be done on Mac.
I had difficulty with playing the test tone from height channels on Mac. Other than that, the entire process works on a mac.
i found the A1 Evo sound better that Audyssey on my setup.
