urgent help SONODYNE SONUS 2605V3 VS JAMO 428
Please listen to various speakers in your city to understand your musical preference. Popular companies for entry level speakers include wharfedale, polk, MS, Norge, Sonodyne, Tannoy, PSB, etc.
Are you looking at a Bookshelf or Floorstander? Usually, for lower budgets, a bookshelf provides more VFM than a Floorstander.
Best,
APK
i am going for separates DENON 1713 and then FS for now 60k max 'no regret '
i thought sonodyne 2605v3 but only 125w 3 way.
but polk audio 200w 2 way tsi 400 both above are 29k...
so unable to decide..
i felt both are good when i had demo..
dont go by watt.
hear them to understand wht is good for you.
audio is unlike video....my taste can be crappy to ur ears and vice versa.......
if u were me wat wud u decide?
That's precisely what he is trying to tell you... listen and decide. You are in Chennai... take a day or two off and visit various dealers and have a listen. Ask any of the FM to come with you and help you audition.
the problem is i have auditioned today sonodyne , polk audio, yamaha and jamo..
so i felt there is really not much diff in the above sonodyne, and polk audio is short listed
as jamo is a bit low end i think.. yamaha was also fine ..its between sonodyne vs polk audio
Did you carry the Denon (if bought) for the audition? Or were the speakers connected to different amp, when you heard them?
.please try 2605 and other towers with 1612 1713 or any amp having 70 watts @ 8ohms.
1713 70watts @8ohms.try 6 ohm tower speakers for better output.
towers need more amp power to perform.
You are facing the same problem as I faced 2years back.
Go, for SONUS eyes closed. The difference is when you listen to music through a CD player.
Sonus would be much more pleasing to your ears.Polk, definitely brighter, not as balanced as the SONUS.
sonodyne HT PACK
sonus 2605v3- 26720k
centrev3- 6450k
di pole surround-12700k
10"rorr 210 sur - 19500k
denon 1713 avr - 31300
sony 3d br p -9800
sony 3d glass - 2800
- 109270/-+cables wires 1500 extra
i asked for 1 lakh the dealer said not poss....
WHARFEDALE HT PACK
FS 10.6 diamond - 49k
centre 10cm -23k
surr di pole - 15k
sub PARADIGM - 39k
pioneer 3d brp - 11k
installation - 5k
wiringcables - 10k
- 1.85l
the dealer is ready for only 10% dis ...
PARADIGM PACK
denon 1713 - 33k
FS para m7 -54.9k
c1 -21.9k
surr s7 - 28.8k
sub para - 39k
pioneer - 11k
inst etc - 15k
188.6l
only 7.5% dis..
pls advice what to go for ..
i auditioned all the above 3 ...wharfedle was best but more budget ...
so pls advice... i have to buy it tmw.......can u suggest the best ...
