USB cable for my Schiit Multibit DAC
Dear friends,
I have Schiit Modi Multibit DAC and I'm using Amazon Basics USB A to B cable to connect my laptop. Now I'm wanting to upgrade. May I request your counsel on a better quality USB A to B cable around Rs. 2000?
Thanks in advance,
Sourav
I do have the same DAC and using same cable. Don't know why I never thought for upgrading the cable :)
Dear friends,
Thanks in advance,
Sourav
Are you still using the modi multibit?
I use the Schiit pyst with gumby.
it is made by a very Good Cable Company "Straightwire" for schiit. Very well made and much better than Printer Cables. Minimal changes in source side get amplified throughout the chain, investing in a well made inexpensive cable is good idea.
Even if you don't hear the differences , you can be rest assured that this cable is not at fault; if ever you have to troubleshoot for unexpected noise.
For short interconnects between schiit stack, would the normal dth 75ohm coax cable be ok or would I be better off with getting an "audio" grade 75ohm coax? I have sone of the dth coax lying around in my house which I was thinking to use within my audio chain.
I use a wireworld silver starlight from Mac mini to my northstar dac. It is silky smooth, detailed etc etc and was a pretty good improvement over a DH labs USB I had prior.
the DH in turn was good improvement over an Amazon basics USB
in audio everything has a potential to make a difference (good or otherwise). It just depends on your system and your ability to perceive the differences.
