saikatbiswas82
Yes, i use the galvanized i.e. transformer version. Dac is burson conductor
Great. I am also planning to order digi+ transformer version.
Great. I am also planning to order digi+ transformer version.![]()
I am building a low noise 10va linear psu for my raspberry pi [emoji4]On top of this i even power the rpi with a power bank. I am sure it helps rather then powering it with a mobile charger
I Use moode audio distro and kernel latency i have selected orion which sounds better to me then default latency
Use a 16 gb pendrive for storage as of now. Plan to buy ssd external drive for strorage as i feel ssds would create less electrical noise then conventional hdds as there are no moving parts and ssds also require leseer power
Lastly and most important plan to build a proper cabinet for the rpi
One more thing we should not forget that USB input reclocks every signal that it receives...so better clocking mechanism is also needed alongside clean linear power. USB port is really a life saver but if we look at a $100 solution with a better clocking mechanism (like tcxo) we won't be able to get much value out of it IMHO.Been reading this thread. Took quite a while.
Sad thing is that USB is getting a bad rep for the wrong reasons.
Personally, I feel USB rocks. It is not called "Universal Serial Bus" for nothing.
From version 1.0 it has been using differential signalling and speeds have improved with 2.0 and 3.0. With differential signalling is not affected by things like ground bounce, etc.
The culprit is the power section of USB. Unfortunately, our PCs or laptops are shrinking by the day and more is being crammed into them. Power supply is the number 1 contributor to noise. When you have noise at PS, this permeates through out the PCB. After this is the high speed signals on the PCB. We have GHz and MHz signalling all over the place. Noisy buggers.
Now this noise leaks to the USB ports too. So when you connect a device to USB port, not only is data being transferred, PS and PCB noise is also coming through. If you are powering via USB, don't expect magic.
The best solution is to put an isolation element between laptop/PC and DAC/electronics.
Even a simple hub will do the trick as long as the hub itself is not noisy.
Imagine not having to deal with USB/OPT/COAX/RCA/HDMI/FireWire combinations but sticking with a simple and ubiquitous solution like USB. Life does become easier, doesn't it.
Please don't put more converters in the chain. Clean up PS or provide isolation.
Raghu
Raghu
Hi rahghu
what you say is true but then without isolation there is no way out
the regen and stuff comes at around 300 usd which is not really cheap
Hubs would be again be noisy as they have a very basic power supply similar to mobile charger
If there are hubs with good quality ps please do post links
Here is one from Schiit audio.
Schiit Audio, Headphone amps and DACs made in USA.
They call it a USB de-crapifier. Essentially provides isolation and re-clocking
Raghu
I am using Modi-2-Uber via USB and don't hear audio issues.
Did a simple test.
Player is foobar2K. Laptop connected to DAC via USB.
Play the song and mute at foobar2K.
Turn up the volume at amp or active speaker.
No noise. So I don't have any serious PS noise leaking through.
Or even if it does, my ears cannot hear it.
Thus I don't need isolation.
Being said that, there are other brands as well that perform their job nicely and may come with a different sound signature. Its purely upto the user whether he/she likes it or not.![]()
