Velodyne impact 12 Vs. BIC America F12 / HS100II
nicenicenicee
Delhi
Experts,
What would you recommend / vote?
I have recently bought Pioneer AJ series 5.0. Hunting for SUB.
Has any body auditioned or used both of these subs?
Apart from experience technology / build quality wise what do you think which one is better?
Velodyne has its reputation for being in the subwoofer industry for over 30 years while BIC America seems to be ruling the audio market and providing the punchy bass.
There are online comparison reviews available for you to decide...see a couple of videos over YouTube to get some idea....
Compare the porting of the subwoofer, if down firing or front firing....check what class amp is used and whats the output in terms of power and frequencies covered....it would be a good idea to get a sub which can blend in well with your existing speakers....you don't want to have a muffled jarring bassy experience when things are supposed to sound as natural as possible.
As far as SPECS Vs PRICE....here it goes.
velodyne impact 12
Built-in Amplifier: 165 watts RMS (275W peak)
Frequency Response: 29Hz - 140Hz
Cone: Coated fiber
Driver: Forward-firing, 12-inch long-throw woofer
Low Pass Crossover: 50 Hz to 200 Hz
Magnetic shielding: No
Auto on/off: Yes
Inputs: RCA line level; LFE; speaker-level
Port: down-firing
Shipping Weight: 38 pounds
Dimensions: 15.1" H x 14.2" W x 18.9" D
Sensitivity ??
Gold-Plated Terminals ??
Impedence ??
MSRP: $379
Warranty: 5 years parts & labor on driver, 3 years on electronics
BIC America F12
Built-in Amplifier: 150 watts RMS continuous (475W Peak), 12-inch injection molded long throw woofer; BASH designed amp
Frequency Response: 25Hz - 200Hz
Cone: ??
Driver: 12-inch woofer, Front Firing
Low Pass Crossover: Adjustable crossover, adjustable volume control,
Magnetic shielding: Yes
Auto on/off: ???, automatic signal sensing (i hope it is same as auto on /off)
Inputs: Inputs for both Dolby Pro Logic and Dolby Digital/DTS
Port: ??
Shipping Weight: 42 pounds
Dimensions: 21H, 19W, 22D
Sensitivity 90dB
Gold-Plated Terminals Yes
Impedence 8 ohms
MSRP: $185
Warranty: 5 years parts and labor
Specs wise BIC F12 is clear winner, any other point which should be considered about velodyne, else in $184 (21K INR) , BIC is a great sub over velodyne (32K INR)
Please audition the both models and decide. Personally I vote for Velodyne.
But Impact series is an entry level one. You can also consider Boston Acoustics A650 subwoofer, a good VFM product.
I am based in delhi,
Do you know where it can be auditioned in delhi.
If i am not wrong avenue sound (Mumbai) is only delaer in india.
any FMs from delhi who owns F12? and kind enough to give Audition?
I am using the Boston Acoustic ASW650.....300w RMS (650w peak)...performance is great...VFM.....
