Need help on choosing a sabre based dacs. I have audio gd DAC which is very good for its price and slighlty on the warmer side which I choose to pair with my proacs. Now I am going with the spendors which are not as sparkling as proac . I need some DAC which is exciting , energetic and a tight base, and assume saber based should help.
-- headphone amplification is not important
--- should have a very good USB implementation as I will be using directly with PC. No expensive transport or additional adaptors
---- ability to connect to power amp would be a plus
Can you share your experience with above DACs. Also pls add more into the list . budget is around 75k
I am also open for used ones.
Sent from nexus 7
Sent from nexus 7
