Looking to upgrade from Wharfdale 9.1(Marantz PM7001 amp) to MA BR2.
Makes sense ? Or shd I be looking at larger speakers like the 9.5's ?
Confused.Welcome suggestions.
the MA BR2 is much more detailed than your warfedales 9.1
its a definite UPgrade (speaker wise)
however the problem i see is your amp
A marantz with MA BR2 !! - i hope you listen to "chamkila" music!
the highs will get irritating!
i would advice these speakers but not advice this combo unless you hear it and like it.
Also do not hear just one song- please try auditioning for an hour to notice if you feel fatigue
With the marantz amp i would look at PSB,KEF,Quad
if youve got a 20k budget i would look no further than the PSB B25 with this amp or a MS 906i or the KEF IQ10
if youve got 30k get the JAmo C405 : i would bet this woul go really well with that amp
BTW : whats the budget
Thanks v.much.
Shall give the C405 a listen - fits my budget of 30k.
BTW what amp would you recommend with the MA's ?
The diamond 9.1 is an excellent pair of speakers. From the Marantz series, I have paired it with the basic PM4001 to the PM15S1 Reference amp. It did have its limitations but the sound was always smooth and fluid. So I wonder why you want to change the speakers in the first place. If you want an even full bodied sound, why not add the excellent SW150 to it?
Unleash_me
What in your opinion are the limitations of the 9.1 ? I use the 9.2 and would like to compare notes.
If you have taken decision to upgrade, some models worth considering are Usher S520, Quad 12L2, B&W DM602, MA RS1, KEF iQ3 etc. These could be substantial upgrades but might not fall into the same price range.
Cheers.
Hello Gobble,
I flelt that mine were a bit shy on bass, so while upgrading my HT, I moved the SW150 to the 9.1 hifi setup at that time. With a lil tweaking, the sound was near perfect! My Holly Cole and Clair Martin disks approved of the same
Sorry I'm not familiar with the 9.2s.
Cheers.
We use essential cookies to make this site work, and optional cookies to enhance your experience.
