wharfdale speaker 9.2 problems-help plz
n_sachin84
bangalore
HI ,
since yesterday my wharf 9.2 is not producing correct sound.one of the front speaker is giving abnoraml sound like cracking of sparks ,like cheeeer cheeer amd after that no sound and some times amp switches off.
what is the problem?
plz help.thanks
IMHO u should call the retailer from whom you bought for this problem and before that you should recheck
1.whether your source has any problem
2.wire L/R are not connecting to each other or broke...just replace each n every item and check whether they have no problem
3.Guess your amp protective circuit is switching on as ur speaker wire are inter-connecting...
Hope ur problem get solved
