Which is the better AVR for Sonodyne SOnus 2605 - pls suggest
What I meant is that they are not so willing to give you hourlong demos like the other HI Dealers of Kolkata
Yamaha RX 371/373, will it be able to drive the 2605s? I am concerned about the AVR's capability to drive these, powerwise the specification seems allright in paper. If anyone has any experience regarding this please share.
If you look at the specs of sonus you will notice that it is capable of handling continuos power of 130 Watts at 8 ohm impedance. However if you look at the specs of 371 or 373 even their dynamic peak power at similar impedance is much less and needless to say the continuos power is also less. Does this mean that 371 or 373 never play Sonus? No, they will but at high volumes there will remain the potential to damage both unless amp shuts off itself automatically. Remeber that amp / speaker matching is a very debatable subject and apart from power matching there are lot of other things to consider. Some useful readings below
Ideal Innovations - RMS and Dynamic Power
What's the difference between Continuous RMS and Dynamic Power ? - Audio & Visual
How to Match the Speaker Watt to the Amp Power | eHow.com
You can try Yamaha RXV 473 ,it will be better match for 2605.As Yamaha AVR's are little brighter than other Brand AVR's.
hello everybody, i have been searching for a good, budget HT set up for my home, after few auditions I have selected Sonodyne Sonus 2605 V3, front satellites, Sonodyne Rear dipole V3, Sonodyne center speaker 2401 V3, Sonodyne subwoofer, Roar 210 along with Denon 1513 AVR, I will like to have sugesstions from the forum members, is this set up good, for the price I am paying for it is Rs 89000, plus the cabling. Will the denon1513 can play these speakers. otherwise i have to buy Paradigm cinema ct 100. Please suggest me at earliest as i have to buy with in this week.
