Besides energy savings of course, why do you hope it's class D? .Another WiiM product for this year....
Hope to be Class D
If it were me, I'd hope that it was Class A with a 1000 watts of power in the abovesaid tiny form factor and a miracle to help it along.
BTW, considering that it has HDMI, and I'm assuming HDMI ARC, this'd be the amp to get, provided it has half decent SQ of course. It's seems so logical, yet strangely missing in the budget segment of amps. I'd imagine if budget soundbar manufacturers can do HDMI ARC, there should be no problem for hifi manufacturers to integrate the same into their "integrated" amps
It can actually - look at the SMSL VMV A1. it's a class A amp in a form factor that is smaller than the above-mentioned Wiim Amp.I didn't know that Class A form factor too would like Class D. Mostly class D or class AB amps are seen in the market or released
Yes it is an all in one AmpI assume its an all in one streaming amp.
Would be a good option for those on a budget.
Just add a psir of speakers.
YES for one simple valid reason is that they hear to their costumers feedback and try to solve, improvise, update their productsYou keep a close eye on all WiiM news Thanks
Wouldn't it be cheaper to add a Fosi V3 to Wiim mini or pro?WiiM Amp on the UK HiFi Show priced at £299
For stereo systems and those with a "Separates" mindset, this option should be a better fit.Wouldn't it be cheaper to add a Fosi V3 to Wiim mini or pro?
Didn't notice it had HDMI. Finally, looks like a cheap amp which finally got the fundamentals right.For stereo systems and those with a "Separates" mindset, this option should be a better fit.
The Wiim Amp with HDMI input is particularly well-suited for TV setups.
looks like very nice productWiiM AMP Stereo Network Amplifier Grey
The WiiM Amp is an amplifier and streamer that's as compact as it is versatile and high-performance! It lets you distribute your music extremely simply via DLNA, AirPlay 2, Bluetooth (bidirectional) or Chromecast.www.audiophonics.fr
