Xgimi H1 - Need your views..
Difference between Z4 xgimi (aurora) vs H1
Display technique 0.45 DMDRGB-LED - 0.47"DMD RGB-LED
Luminance 700ANSI lumen - 900 Ansi Lumens
Contrast 5000:1 - 10000:1
Standard resolution WXGA(1280x800) - Full HD (19201080)
Projection ratio 1.2:1(76-inch@2M) - 1.39 - 1.5 :1
Optical zoom? No data - 1.1x
CPU (4 core 1.5GHz)- (Mstar 6A928 Cortex-A17 Quadcore 1.7GHz)
GPU Mali-450MP4 - Mali-760MP4
RAM 2GB DDR3 - 3GB DDR3
Storage 16GB eMMC - 16GB eMMC
So Clearly H1 is the winner since it can project full hd (1920x1080p)
Rajesh
Have you owning H1??
Yesterday seen Demo in one youtuber home as he owning z4 aurora. Thay Youtuber gave demo and explained the functionality for about 30mins as he is an Tech geek having so many gadgets in his home. Seems he bought from local vendor not authorized one. No warrenty. He used for one year and selling price is 40k Z4 aurora. He is having Xbox one and Ps4 and Ps vita all are sale purpose. If any one interested, I will share his contact details. He is Chennai.
Sent from my SAMSUNG-SM-N910A using Tapatalk
Rajesh
Can you tell me H1 takes how many meters to project 100inch??
Approx 11 feet distance between PJ Lens to screen, you can get 100 inch diagonal screen with Xgimi H1 assuming throw ratio 1.5 :1..
If the throw ratio is 1.4 : 1, the diagonal size will be more(Approx 108 inch)..
Sorry for asking so many questions:)
Am new to this and yet to own one PJ.
For achieving 100 inch diagonal screen.
What is the space required??
Please say Width and Height in feet?
What is 1:5.1??
No worries..
For achieving 100 inch diagonal screen.What is the space required??
Atleast 11 feet distance between PJ & screen..
Inches are easier.. Between 80 - 85 inch wide (7 feet), 48 - 52 inches height (4 feet).. Diagonal (approx 100 inch or more)..
What is 1:5.1??
Throw ratio..The metric for calculating the image width.. Not diagonal..
Just for calculation..for every 1.5 feet PJ being away from the wall, you will get 1 feet wide image on the wall (not diagonal)..
More info on this link - LCD & DLP Projectors - How to buy a projector
No worries..
Elango, saw demo of z4 aurora in that same FHD video file looks better playing from PS4 and not in direct USB play?
So do I need to hookup extra gadget like Nvidia shield tv for better playback??
As Nvidia plays all the files without any glitches and HDR 10 support.
Please advice.
Haven't used the PS4 (or) Nvidia Shield, so can't say for sure if there are any video processing enhancements..
I think not reqd.. Z4 Aurora has Android OS (kitkat 4.4).. If you have media player installed on the Z4, it should be more than enough..
But when I checked it is struggling to play 4k 10bit video from direct USB drive. The same video file played well fluidly in Ps4 as super clear. That's why asking.
As part of black Friday deal shield tv $30 savings going 149$ - 9.5k.
May be the USB playback has limited video decoding capability..
Which media player did you use on Z4 to play the 4K file?..
Same USB drive plugged into PS4 and played from PS4. It is worked well.
see H1 Through ratio is 1.39-1.5:1,
so for 100inch (8.33 ft) you have to place your projector lens at
a distance between 11.50 to 12.50 ft from the screen and in meters it will be 3.5 to 3.8 meters.
Not yet, after reviews/feedbacks from elangoas then will decide..
thanks
rajesh
Most likely you might have used the PJ inbuilt media player to play the file.. Some media player gives you the option of using H/W & S/W decode.. May be one such application might get the better of Z4 USB capability..
thanks
rajesh
Am also waiting for Elangos review. Post Elangos review I will also pick if green signal comes.
