I did not find the option to bit stream on Xtreamer.
Following are the settings I use: (Xtreamer to AVR through HDMI)
1) HDMI Audio On
2) Digital output Options on Xtreamer are
a) DTS/Dolby D5.1 CH
B) DTS/Dolby D2.1 CH
c) AAC/FLAC/OGG 5.1 CH PCM (HDMI)
For Audio Music: (FLAC/OGG/MP3) there is no difference in any of the options and the AVR always displays Audio Signal as
Format: PCM, Sampling -44.1 KHz, Channel:2/0 , Bitrate:----.Dialogue:----
Does the above mean that Xtreamer is processing the digital signal and if so will I get a better audio if I replace it with a high end Player keeping all other components same.
For Movie Rips:
I am not having any issues here and I am getting the following.
I) Rips with DTS/ Dolby D 6 Ch: - Choosing option 2 a DTS/Dolby D 5.1 CH shows Audio Signal as
Format: Digital, 48 KHz, Channel 3/2/0.1, And Bitrate: 384 (varies based on the Rip), Dialogue: +2dB
II) Rips with AAC 6 Ch, Choosing option 3 b AAC/FLAC/OGG 5.1 CH PCM (HDMI) gives audio signal as:
Format: PCM, Sampling 48 KHz, Channel:3/2/0.1 Bitrates: ----.Dialogue:----
For Movies if a wrong option is chosen the Audio is PCM, 48 KHz, 2 Channel
Please suggest any changes.
