Anyone familiar with ELEKIT TU-8200-DX ?
SBE-Audio
Ahmedabad
HI,
Was wondering whether anyone has experienced ELEKIT TU-8200-DX (DIY vacuum tube
Class-A amplifier Kit) ?
Any opinions, ideas, knowledge of where to procure from ?
Thanks,
There was one member from Mumbai if I remember who built the preamp version of the elekit, search on the forum.
I am using Elekit TU-8200DX Tube Amplifier from last 3 years, Trust me it's very good. There are tons of positive reviews for this Amplifier.
You can buy it from Grantfidelity. You also have an option of buying professionally assembled version with an additional cost of $125.
If you have good soldering skills then you can DIY.
Noted, with thanks
Which loudspeakers, in your opinion, are good with this low power tube amp ? Also, which ones are you using with this amp ?
I am pairing my Tube amp with Dali Zensor-3. I am very pleased with the result.
Initially I used to pair it with Kef Q100 and then upgraded to Dali along with KT88 Tubes. Here is the small demo, Sorry for the poor recording.
The good thing with this amplifier is you can play around with tubes as it does auto biasing.
