One of my friend assembling speakers.he can make speaker according to our requirements. and price is very very cheap. so i want give a try. I am planning speakers with subwoofer (6 ohms) and a twiter. What are things to be consider.
Frankly speaking.. no idea.mostly speaker mount. After discussing with friend i can decide. Please share your thoughts on speaker and twiter configuration alsoHow have you planned for Atmos speaker?.. Fixed directly to ceiling (or) with a speaker mount ?..
i will share room layout shortly. i need suggestions on speakers configuration. According to denon surround back specifications and As per my knowledge i am planing with 5 inch sub woofer(6 ohms) and twiter. are they good according to specifications? please share your inputs.I have mounted the in-ceiling speakers on-ceiling with DIY enclosure.. Here is the thread for detailed info - https://www.hifivision.com/threads/...concrete-ceiling-for-dolby-atmos-dts-x.67107/
There are some ways you can mount the regular small speakers on the ceiling using brackets (or) some easy DIY methods..
Please share your room dimensions, your current speaker placement and the walls in your room... Even a rough drawing in paint brush, should be enough to suggest you some ideas..
Yes, but is technically not strong. We have to give drivers configuration and other details then he will buy in wholesale shops and assembling themDid you have any of your friend's work?
Finally DIY completed.
Really superbRs2500 for two atmos speakers !!
That's the fun of Diy
By the way...how is the atmos effect ???
Hope you have introduced passive crossover circuit board/atleast bipolar capacitor inside the box for tweeter connection.Finally DIY completed.
@elangoas thanks for helping me to get best output.
Details
Speakers
DainTy 8ohms max output 70w, price 400rs each.
Wooden box 400 rs
Bolts and carpenter work 300rs
Amazon basic wire 500rs
All together comes under 2500rsView attachment 28338View attachment 28339
Just added a small condenser to Twitter. I dont know much about technical details friend helped.Hope you have introduced passive crossover circuit board/atleast bipolar capacitor inside the box for tweeter connection.
