cha_indian
Keith, how to connect 'In phase' and "out of phase" ..
In other words, normal polarity and reversed polarity.Keith, how to connect 'In phase' and "out of phase" ..
cha indian
i think joshua and me have about 125 gms / per speaker
i like it
My TL FS sometime use more than 1KG of internal damping. Not sure what would be right for a vented enclosures.
I suggest you use some gasket to bring up the tweeter in line with the baffle.Sbg - subwoofer :done, X-LS : pending - the tweeters flush mounting depth gone is off by 3-4 mm. - reworking.
@Capt: finally!
Odyssey must have completed his build, I think. He was part of the cabinet mini GB (by magma). Of course he is spoiled with choices from his stable of speakers
Capt, did you opt for the Sonicaps? It is truly a worthy upgrade.
Take up this build on the double. You don't know what you have been missing!
Stationery shops stock craft foam sheets. Use that to cut out gaskets to fill up the depth. It will also isolate the tweeter nicely from the cabinetX-LS : pending - the tweeters flush mounting depth gone is off by 3-4 mm. - reworking.
Stationery shops stock craft foam sheets. Use that to cut out gaskets to fill up the depth. It will also isolate the tweeter nicely from the cabinet![]()
