Best Speakers for Denon 2311
eddy_lepc
Hyderabad
Guys,
I am planning to buy Denon 2311 from canada this month and looking for speakers to match them.
I prefer 50% music and 50% movies and have mid size room. I somewhat hearing lot of speaker brands like B&W, Whraf, MA, MS, QA which fit Denon.
I live in Hyderabad and had few audition in Profx, Vector and SBT.
I need expert advise to suggest me good speaker for Denon 2311 with 75K budget.
Thanks,
Edwin
Eddy, most of the speakers you mentioned will work with the Denon receiver. What is important is that you like the speakers. At your budget range you should look for QA, Wharfedale, Mission, etc. Audition as many as you can and pick the ones your ears like.
I did audition on Paradigm yesterday and loved those speakers. I know its above my budget, but still i can expand if the cost comes below 1.25L
Can you guys share your comments on the below configuration and pricing for the below speakers
Monitor 7 Front Speaker
CC190 Center speaker
ADP 190 Surround
DSP Sub 3100
Edwin
Eddy,
As per my understanding Paradigms are made in Canada and you can get a better deal there. I would recommend bringing it from there if Paradigm is your final decision.
@ Eddy - If possible I would recommend that you hear out the Deftech ProCinema 600. I'm thinking the PC800 would be an overkill.
Are you planning to connect two sub woofers? never experienced in HT, can you share some of your experience.
Thx.
@eddy I too am looking for speakers for denon 1911 which is slightly less power than the 2311, but rest is similar.
I checked out the Paradigm monitor 7 today, below is the link to my review. best part is you will be able to bi-amp the towers with the 2311.
http://www.hifivision.com/speakers/11463-tower-speakers-denon-1911-a-3.html
Also had checked out the def tech pro cimena 600 (if you are interested) below is the link to that review:
http://www.hifivision.com/speakers/11463-tower-speakers-denon-1911-a-2.html
do let me know what you think...
