prosenjit
hello team.
I planned to buy a blu ray player.sony-BDP-S380.
reasons-cheapest on my criteria.
which is it can decode as well as bit stream lossless all sound formats.I have an avr which can decode all by the way...so my main concern is the player should bit stream output by not decoding it.specifications showing that that model has that capability.
now my question---about REGION CODING what should I check??
if I buy it from e bay india/local sony showroom.because suppose the player is region C and I play a region A bd disc so it wont read it..am I right??
so what should I check for??
I will be mostly playing bd discs rented online from moviemart india.and sometimes from my external hdd.
thanks in advance
thanks in advance
