Can you put on detailed notes at painting part, I am thinking of painting couple of enclosures
Hi JM,
Please read Post no 4 in the below link
http://www.hifivision.com/diy/58852-my-newly-built-sub.html
Sadik
resembles the PSB Alpha B1 bookshelf speaker..
good work on the carpentry and look forward to the finished photos..
regards
Edit - i notice ASB Audio on the back plate - any back handed compliment to PSB Audio ?
Hi JM,
Sadik
Amazing workmanship. Congratulations. Nice bit of the name. Proudly Made in India [emoji106] .
Is this only for hobby or do you make to sell as well? Just wondered because of the nameplate, I'm not looking to buy.
Admire your woodworking skills!! I went through your painting procedure and in that you had mentioned that you spray the NC Putty. Can you please elaborate on this? Do you dilute the putty with something before making it spray-able?
Venki
@ Sadik
Awesome build quality and good looking speakers. Will be eager to get some subjective listening reviews.
About the box - Hope they are rigid enough as i did not see any bracing inside the cabinets. I would suggest you to go for an interlocking joints if you want to avoid braces. This will ensure a rigid cabinet free of panel vibrations in the long run. I am not sure if the cnc machines do that kind of cutting where you can put interlocking joints for all the panels.
My 2 paise.
Excellent job Sadik. They look great and I am sure they sound great as well.
Sid
