Book Slelf for Small Room & Multimedia Speakers
Now the above Photo lead me to another way of thinking. Just imagine the lines formed are white colored, enclosure is black mirror finish... how will it look? I Found a way to get this texture naturally. I need some more R & D to do this but i am sure I will reach the Goal. And may be in my next Project I will use this texture.
End of this Project.
Sadik
the paint basically has not gotten time to bond with the surface, which could be due to multiple reasons including surrounding weather and some kind of reaction with primer coat/putty not having dried completely.
incidental occurrence which has given you satisfaction so that is good. you have done good work which is giving you and us satisfaction, best wishes
For painting MDF or plywood, a good coat of putty is a must. Followed by sanding to even out the surface. Followed by primer, followed by sanding. Then only the actual coats of paint can be applied.
Completely agree with you both and same is my Procedure. Only thing is I apply putty by using spray gun & avoid using primer because here putty acts a primer coat so why waste extra bucks and labor for primer. I think you have read my complete thread any you may have read my post regarding my painting procedure. But in this case at the final moment there was an accidental damage caused and also some reaction caused in paint which lead in getting the textured finish. I found the cause why the reaction has happened and i will do some more R & D using 2 different shades to make the texture look good.
Secondly even with this reaction there is no paint peel off from the surface & this is the main reason to do the R & D regarding this texture finish.
Sadik
I am not an expert on painting (or for that matter anything :o) but I think you sprayed putty which means it was diluted (water ?) and after putting final enamel coat which dries quickly the wrinkles appeared. In other words you should have given more time to dry the bottom putty layer.
But overall your speakers looks nice. Very good work.
Regards.
Regards.
The Putty was diluted in NC Thinner and after drying only i was able to sand it.
Here is another Pair of Bookshelf Made from Iwai Drivers. I am not uploading the built process as this thread already had all the built photos of my earlier built. So below are the final photos of my new Built Bookshelfs
QEPC-YQ6wt6dAX2JPjaIMO2yY20vYaDjh4icMsmB2QBGh06OvA6MHZ36eqf1hA4928vQlYaULatD_GrnAtggD0SFYBw45PYp5F9Dkr347Br6gxHuAAGeLG-nujN8pW6nGb0w3J2Lrsyb_yR9ymRmwArL3GWiLFzEtQk7dZ9AHIDJ5zl1Hvu4OcB4NlC5XKWhSVfDffekAcBX27DerW-IajebLtvZK4WokQeGqflLS2fS00O-MTsqymsriWhu0ZVSZhmhfNHRMP6MmQ0bLJ3M39GLGT5WSW6SF8IqaDg8a0K0mkSlMDr21Ag_FvkeTNxOHdadtRTpgB2vvzuLLzSNkgjhYijaoovi6brlbq9vn6PsvmrvfHEzmNEbdyPO3JOOgsN9G3LPIEq1qmmF9AUcQZqR79pFrqfbWykothVT_pM2fdf58duPUuQOf4mJqqGk6y1AoGPWjdjYNZKbNR9soF2a7J-1tgRLcA4TZqfR8idVG3R0M947g42kwRcZmvKeT_72Qvjyrr-W4OcFFHIIhEdWkl-9WuWM8pZRg24RKeLfds2PjKJKQsZP_SIeS110EZaEMynMqCLaykzo93ZUeE0G0GUhwkAGp2_r22w=w1231-h923-no
7-ShfOsFrYtDx2IRhYv5rpYtj7KYIZhkO7UVV9vsK3FmY6Lr4I35gmgz6BlhwnWJOMwLNxjHnKa-V3rqsCgKcR2AujU2A6kjXCzcvuuwPO_WexWzFNv9cXlfATgOgiQq0jENjipogxo-oftL1lf4PPv-w52_jRM955e6Zkp8oTY4wHTffKNDEMBoiggjOznlON_Oz4trJ_Hpm3KbHL4XYAzaVf4Ykpl-6A7TR6uGogx2aUSPrqSnbASdnwK_8YQdzwUtUtyiyMT_pa_84c-iD9LEX7Ts9KQwyYx5cfpn7RmXPjUR02Z4r_IGjBLTLQB1szgRoxtn7bJhFccSgutZblx8iVnDXrHVC50VMPeNosHJF2EDXdf16fPtfoZXM_4RyJylpqcncHtNh4w6BCwCHp4Uk4roiyiE5dIzebsPn2t4nIB89fcWzAs9taTljXu_oMQCC6Spqr-4yZN5eh7baU_2tavX_j6Oj7jJ_tjTiOCpfs6ELJQrpEssRR3vC383EgRzbUDd7cVI7Sov3QerdnnHcuaTi0qYx9WGGpDDjbZtNqwOan74CALnEIsojZoVJ10IphFFlxLEZBc3-bghc3jpJOc5ReFbXwJ1sjA=w1231-h923-no
MQjM-sDumlhO_P-bAmrh9ARVTOJHPG-0HKdPMhzntGZ7tQIa06Ei6w8qxZOackqd3OorO13D5s23gYqRaS0qePh8MMiM2XVFQEDtaxlte2ordFIYSBsXjxnJ3gpUpTadvEmGYWGY7T2MfV6WZ7ZT7XEH98UiCm--ZiQY1FK3cN7jNJbZ-H-ogkCWo7T3bYM1wBNei63G5mJjq5TNeoDCjd9UzyJkcAPK3fnrPZGI035borDvJhOEQYVNLJ4nwAKtydl7mtCCXCqaIzdL9kPzimZOPaXTXahL2zf2Wwwqvnl5xKmCFNckjLEIcs7__ZiFYDA3sfQQiBQbuswTRZQDYWShHONRudk6-EdujfUIM7B8JophjYwaxT7U4-Qvt1yHaMGn5RkQ3FLeBpzPFyipbcbwv72HJaxwhdec2KUUM1pwyyKiWYsWWKjedcNugiXEozCF4DLxrF6ND6zF43ps_CRv_CzNpgSDMFOPP70pYrjGJFUhmkMGNH6z8mPqx0kKpsVmX7IWwc1rjKiuIunV7B6H9A5AhzjprJ1dhvuS4ofz9s-sB0lQJjw0rZDIUrvbs4NaZ6C9oJR5zXt8W7nQKvL-JVAJez0BTzBMnr4=w693-h923-no
ZJGT8nV68v-VDtU5_vR4mlpbws-FbAibQTnITI0cdgSS5n_d3s916Z7sxyQVb0cdFb-O--eTTOTWlx8Ab85ABXpZzpXM6R7sxGDKrB_7_q6D7oIBiV-BWM8fd6hAZrhbfhLW4AT_lPP3JcEfGdYR9T-7zcN2gpMW-u1INsHR3zvCDaoBtu6-oF5GKGDhrFcJOQlEy4OrJrcL-vlzcrrqQdMllqA_S9umGLAdHC7-kPW2rtCS15yGQch3fypu9Txou9KurUH5AkGfa5K35fXOUknh5m2F5YdQJB1TUj-tnuCicYjjYfbUmuePqGZc0UnVQkC_qaeCIPd3pSG5hwqM1zhBoBkGu1cbrin-cxIHRWYGGlwZgWiSlz9x2vMjDt45w_O_1qoow2IuX6MdFhfNqB30n5ROjW66J_JUSXdmJVGUvPve2LkGt8Ve0QDJeHGxkY3T9HxGzkKiNeCZSGb_BHoR2Pbi505cJIC1E2bdnMqXreYzein3A54wUXtq4WHNF5o9PCo__QPeJ0GydojKOiV-0RwZ6nY7f-cvibPOXxaiJIhYjqIODESqP9htTWA4ATadqJYrybf7ZqDn_LICH-6OXP8E54vsvinFYio=w693-h923-no
gmt5SoiY4sSJW3kSkfwbjDsGpDcvmrz0Ok5AMMtpIUuERSp3tRICEfaFcU6H9wcQO4bs_MGfVFsVbmAAGcwxcgNkdgXSU-1gx0Tl1_YVrL7dokzfZOIcQt8IJ9A1LRdCWpFsnQ6FBmc_bPmcgw_atz1uzAGvjEx9zXs4BEcSGD_IZng-TQ6CiDBBT1EXrs8eGzuL-XR3wF64YepjZOYCjlBhk3GeejzIjNc89K7upSe-yKmrYHiQ7FX_Uren6lny-0aFZRuXYOcSpsSFZP-OjH0BgKuXQbphEO2RTYpDlD9KIc8IVGEiitlYyrLuB9PanxbTwD1hNJ_-ZjvvNkUu3U09SUY-X5a2OhIM6IccZwADTeLfqbv43OVvtUiqgesok4IgOI65BezWYeCEATMXFnYnKTJUQshL5zxNUavdiCmoj5KTGRVfwZueMkJwX70UPkXHNT4ZVOONnG0s665Wr1vgRBz4TQTn1UQyJ-11Uou1acM6AGviYiADbSKF-IQibCftwHL6veTW0ngT09fopK9be169FGK9n1zpcnoVPOT9CdinocND7bytrrZISVuG14oy4iyBHMjammActgDLS1waJGeMwCBa1Bj104Q=w693-h923-no
MyrdU4xOqorPYJRemVU3wlXVEP-RUvifC4VntEIMm7zUE3_2lNajZItv26mjfAHrJlrYEoHIa0i-QfibkLriszBWpXKQfYwe7QnLky6EzSAZDvWCel0ocqb68CUDWA-Boz2TFoSfmsseFy89VxZz6ODPJX2b_-HqOLbCQo2a4T8ZsboGIz5-N8mMl5moKByDc3XdVQVqbrzP7HlOREEVLCVDhDEkigetJbdMz7M3S0CXN97PUSXg03CKxkBAM6FGOh5NVoBQTnyjKWJ36kCorU6adBBeJlPTOX7QhBK8bbDaymXusntEKda53Ko-I18TzGoOngtNHU_ike6hAzrNe93OBaqc6eCXEqCY5Ul_r0oiGOc1qzclVY28Kx7hEq56xJ0DdeoC532djlTvHvFofNdIR9vwYmxub7VNpmPdUqt8Q14Utcc9rbJ1YnXCCRwrdMo6YQdnU8Bq6-P-n0mX_p2WG9wXUwBuUubwlQwxiDYUTdBu7DJTiDkItApBMaoNE-nFmV8ngA25RZYWk0MDhLyQcECoUEret1o-_naf4VMZjraUU2kvZsOkoJ6-2q23hXvZeZTdY5EGPgT08n6DH8PbCIpG8hzhpLr4c9M=w693-h923-no
Sadik Bhatkar
Sadik Bhatkar
Congratulations they Looks absolutely gorgeous in fit and finish, How many hours do you play these beauties before handing them over?
I'm looking to build 4 pairs of satellite speakers for Atmos and Surround duties, a front ported design is with hinge to turn directions to suit the requirements, can they be modified, or do we need to design it from scratch? Anyways I'll PM you the details
Got the speakers from Sadik on Sunday. They are beautiful, much better than many commercial offerings. The workmanship is excellent. The sound quality is amazing. I am using it with my DIY DCB1 and Amp Camp amp. The highs are too good, and so the bass. It sounds fantastic with My TT and also Sony PS1 CD player. My sincere thanks to FM Aniket (the designer) and Sadik bhai to build for me. I would recommend these speakers to anyone looking for very high end sound in affordable price. They can be compared with any good speakers irrespective of price.
The only drawback (not in my case),is they have back ported, so there should be enough distance from back wall else they gets boomy.
Pardon me for image quality and dirty setup. I am yet to set them properly
Sachin
Thank You Very Much @ Sachin, The reviews from one of the reputed and senior member of our Forum means a lot to me. I feel myself lucky that you like my work and most important thing that you like them singing. Thank You again Sachin.
Sadik
