Bookshelf Vs In Wall speakers
well in wall as per my suggestion wud not provide good sq. as speakers do need some space and acoustic treatment that is done inside of a BS or FS
Flush mounting loudspeakers extend the speaker cabinet front baffle infinitely. The advantages are many. Below are some links that explain more
Soffit mounting of control room monitors
Genelec Oy - Is flush mounting loudspeakers a good idea?
Loudspeakers: for music recording ... - Google Books
Also note, flush mounted speakers will produce a 4dB to 6dB bass boost that has to be re-calibrated back to a flat response with a combination of high pass filters and bass low shelving filters available on external equalisers designed for this purpose
Also note, trying to flush mount bass reflex speakers with rear ports is difficult, as the ports will get blocked inside the wall
