RobertJason
Long time reader, first time poster. I have been on a journey to find bookshelf's that I love and can listen to for longer than an hour.
Current System:
Yamaha CD player
Yaqin MS-12B tube preamp
Parasound 100W amp
Dynaudio Audience 50
Wires (inexpensive hosa's, multi-strand copper for speaker wire)
I've been searching, literally, for years to find speakers I love as much as the Dynaudio's. The thing I love is vocals, resolution, piano, realistic tones. I can hear the piano pedals being pressed, hear a zylophone in the background, things I never knew existed in a track until I played them on my Dynaudio's.
The delimna is that I'm getting older and listening fatigue kicks in VERY soon now (within 30 minutes). I, unfortunately, listed to a lot of compressed music and I don't know if the Dyn's are bright or if it's the compression but I can no longer listen to my 10+ year favorite speakers.
I'm hoping you can recommend a speaker that still has resolution (ie, hearing piano pedals being pressed) but without being bright. I've tried EQ'ing the Dyn's and that helps, but as we all know EQ'ing kind of ruins a speaker, I'd rather have speakers that are naturally low-fatigue.
I've done research and am considering many including: Ascend Sierra 1, Wharfedale Denton, B&W 807.... The budget 'may' permit Harbeth or Splendor, but it'll be hard to spend more than $800 used. I don't mind buying used either.
I'm very over the 'monitor' neutral sound. Clinical, non-forgiving, and Analytical are not a good fit for my purposes. I'm okay with falsely warm as long as there is still detail and resolution in the midrange.
So what do you recommend? Bookshelf's that have detail and resolution for beautiful volcals/piano but not bright or fatiguing!
Please keep in mind I don't have a budget to upgrade everything. Just looking to drop $800 or so and switch out the speakers.
THANKS for your advice! - Robert Jason
Current System:
Yamaha CD player
Parasound 100W amp
