Budget BD player : need help to choose
Anchanda
bangalore
I have 42'' LED LG TV (LH90QR) + Denon 1910 with Jamo 606.
Looking for BD player capable of
- Playing multiple video audio format.(TV has USB but its limited with format.)
- Wifi / Elethernet capable
- How much size USB hard disk is supported ? which file system it can read FAT/NTFS ? Is there any technical limitation on the size of .dat / .avi file ?
- How can we play youtube on BDplayer when it does not have browser ? educate me. :o
- when we say ethernet , does it get a mac address / ip address ?
I am inclined toward LG-BD550 due to simplink feature (TV and BD player will go hand in hand and I will not be needing extra remote ) -- any comments.
Appreciate you help in decision making. Thanks in advance.
I'd also suggest you to go for LG BD550 model as it playes all the media files and have support of all audio codecs. I traid many of them and it went very well with all of them. I guess it is going to replace the medaplayers and it's very cheap too. I think you will get it in 7.5-8K. Just one item I can see missing with with thi model is it has not got digital optical out but it has hdmi and coaxial out. It supports wifi also.
+infinity, LG BD550 is an awesome BD Player. All in all it comes under top ten BD Player:ohyeah:, What else do u need. I myself has ordered this BDPlayer:yahoo:
