Budget stereo floor standers
corElement
gurgaon / Delhi / NCR
Yo, I'm thinking of getting a norge 2030/60 integrated- was wonderring if anyone could tell me if I could get it in ncr/delhi region hopefully around the 6k mark if not what range.
And what budget towers or wall mounted shelves would you guys recommend with it. ( preferebly floor standers ) within the 10k mark
I recently visited Norge. 2060 is Rs 8770. Didn't ask 2030 price. Reference 2000 is 13000 (if I remember correctly) and Concerto Gold 1000 is Rs 11000. In case it helps, tower Norge TWR 135 is Rs 20000. Bookshelf is much cheaper (forgot the price). A floorstander closest to 10K may be Yamaha NS7900 (Vijay Sales outlets in Mumbai list them at Rs 11060, whereas Yamaha Music India website says Rs 17,596). But make sure you audition any setup you are looking at with your own CDs (songs you are already quite familiar with).
Joshua
I thought you recently bought a Jamo system:confused:
Anyway. stretch your budget a little and you will get Mission M33i at around 14K. At 10k it is very difficult to get even a decent floor stander
yeah but this is something i wanna get for my mother later this year for her birthday so I'll save up. How do the missions match up with the norge.
I'm also open to 2nd hand stuff. The missions have just 1 driver and tweeter, isnt that kind of bleh for a tower ?
Joshua
2060 is 8780? ouch, the 2030 is 30+30 so its really low, dunno if it'd be worth it in comparison to a 2nd hand thing with better specs. or am I wrong?
