Cab build for university 312 diffaxial
sachu888
Gwalior,Nashik
As some of you aware I have got these drivers, thread here http://www.hifivision.com/vintage-audio/57299-university-312-triaxial.html The cab work has started now. I have decided to build simple reflex cab suggested for similar 6201 driver:
The design
I have used 18 mm MDF. The cabs will be painted dark Brown with Duco paint:
The front baffle is directly mounted on the front frame from inside using wood screw. The drivers will be mounted from behind.The back side will be removable.
First coat of primer :
Ready to paint :
Sachin
Hi Sachin,
Whats the Update.... Please Upload some more Pics regarding the Process. Eagerly waiting for the Final Outcome.
Sadik
Hi Sachin,
Sadik
Nothing much, Sanding is done. they will be painted on Saturday and Sunday. I will post more pics after painting.
Sachin
Great stuff Sachin, kindly share some details on how the wood panels on the enclosure are held in place together and details of the paint job, very curious to know.
Hi Reuben,
The cabs are made of 18mm interior grade MDF. Front panel is mounted on front frame from inside(not removable). The back panel is mounted on frame type internal bracing, using wood screws from outside. I have kept back panel removable.
The paint is called Deco? at least carpenter told me so. I think its a Automotive grade paint.Its a long process for paint and different than oil paint. It needs a first coat of Deco primer and minimum 2 coats of special Putty, sanding between each coat. There should be minimum 2 coats of paint for final finish. There is also optional clear PU coat which I did not opt as it makes surface super shiny.
Deco paint can't be applied by hand not even primer. It needs a spray gun. Now the outer surface is as hard as Ceramic.
Sachin
