GeorgeO
I am a firm believer in multiple speakers and multiple amps-that way you get to enjoy all the Chinese, Mughlai and Continental offerings as well as the best of Indian veggie stuff!
I have only one explanation to all this. Every individual likes a certain unique presentation of music which connects him best to the music. QUOTE]
amen![]()
Hi Stevieboy,Isn't loose bass cause by low damping different from excessive boom caused by too much bass?
which you say is different fromloose bass caused by low damping
I think a lot of times the room has a far greater role to play in the bass getting too much in a room and boom then happening. Which is why in many people and reviewers suggest that in typical listening rooms, less bass eg bookshelf versus more uncontrollable bass from floorstander is a much better proposition.
IMHO it is not proper for me to answer this as I do not have his consent to quote him.the room of the person in question was quite untreated from the picture that I remember if that person is from Chennai too and I'm guessing right who you mean.
At least there is some agreement albeit for different reason.I'd definitely agree that my system has looser bass than a conventional two/three way speaker driven by a SS amp which has tighter bass, but excessive boom as a given in a SET-single driver system...
I agree. I have a pair of Audire IO2s along with a pair Dynaudio bookshelves gracing my living room. They both use different amps and sound great with different music.
Yes but not affordable to middle class India. OT but that's why DIY is the best route - if not the whole chain from source to speaker, Saving 50K on one component via DIY route can make extra gear affordable...hyeah:
Same case here to Prem, have been through so many speakers but finally settled on the Rethm Saadhanas and they in a different world. Nothing like a single horn. Period.IMHO.
I am sure DIY must be a good route;
However, I have never had the chance to audition any DIY gear.
Maybe it sounds great - some day.....
Is it really that cheap ????
I am very very keen to make a sub for myself... I have chosen my drivers [the ones I want to use] - they are from accuton - 4 or 8 pieces per enclosure - but I do not know who can make it for me ?
I can work on the 'enclosure' but the electronics [active amplifier] & the x-over is where I need some serious help....
Can you or any one else advise ? Who to go to ? Where to go ?
Suggestions shall be much appreciated....
p.s. Does any person know of a 'commercial' sub that is made ? Who makes it ? Accuton chassis i.e.
http://www.clofis.nl/nl/thiel/C220-T6_kompleet.pdf
This is what I need to use....
Thats the beauty of making a sub. No need to do all this. Get a plate amp, or a pro-amp like behringer. You wont gain too much in terms of money by going for a commercial plate amp. About 500w plate amp will cost <300$. for about 300-350$, you can get a 2 channel 1kw behringer, this can be bridged also.
You do need a high pass filter though (unless going for sealed).
If you are going to be using a receiver, you wont need a low passfilter. If your amp has a sub out, most probably it will have a lpf.
Plate amps usually will have both (check specs before buying though).
Do the cabinet design in winISD, get it checked here on the forums, get a carpenter to make the cabinet, slap the drivers and plate amp in and you are done.
Of course you will face a million small small problems. Mr murphy has a specific law for this:lol:
Personally I would be more impressed with a guy listening to Beethoven on his cell phone, than a guy listening ....valve amp and esoteric speakers which cost a million bucks.
Personally I would be more impressed with a guy listening to Beethoven on his cell phone, than a guy listening to Pink Floyd or Dire Straits on some la-di-da valve amp and esoteric speakers which cost a million bucks.
The question of this thread is will it be 'better' on a Cadence / Lyrita or Rythem? If I understood it correctly....
Hence we need to deliberate on the options...
What is preferred by us / others & our suggestions should be in a position to help the person in Gurgaon to decide... [I think] !!
@stevieboy
"In general and this is my sole opinion, people who tend to like single drivers and SET amps are more focused on the musical side of the music."
Musical side of music?What exactly does that mean?Does music have a non-musical side also?![]()
