unknown cart
Vinyldj
you can get very nice generic Shure M75/M70 styluses from evg jico etc which will be very cost effective - the classic 700 has a very similar signature as the M75, which is the parent of the M97 current cart
Reuben, you missed the N44G
there is a wide range of Shure M75 clones out there - and FM's here have had positive experiences using Shure (and equivalent) styluses on the Classic 700He's looking to use a Shure or Jico stylus with the classic 700. Would these work?
Hithere is a wide range of Shure M75 clones out there - and FM's here have had positive experiences using Shure (and equivalent) styluses on the Classic 700
http://www.hifivision.com/phono-turntables/16931-eei-classic-700-mm-surprises-6.html
