B badrisuper Active Member Joined May 24, 2011 Messages 221 Points 28 Location chennai Oct 9, 2017 #1 Hi Planning to add a pre. Anyone has got good experience with cary audio slp-70? Thanks Badri M
B badrisuper Active Member Joined May 24, 2011 Messages 221 Points 28 Location chennai Oct 11, 2017 #2 I auditioned and liked the warm sound. I will be using it with Mark Audio's A10. Thanks Badri M Attachments IMG_0068.jpg 26.7 KB · Views: 92
R raj12345 Active Member Joined Apr 7, 2015 Messages 141 Points 28 Location Mumbai Oct 12, 2017 #3 But its looking quite cheap build.
Kannan Well-Known Member Joined Jan 13, 2008 Messages 2,516 Points 113 Location Chennai Oct 12, 2017 #4 badrisuper said: Hi Planning to add a pre. Anyone has got good experience with cary audio slp-70? Thanks Badri M Click to expand... Which power amp are you planning to use with it?
A AVM Active Member Joined Aug 15, 2012 Messages 223 Points 43 Location Gurgaon Oct 12, 2017 #5 Hi Badri, I have EAR 864 pre amp and intend to move it. It also has a MC/MM phono. Sent you a PM
B badrisuper Active Member Joined May 24, 2011 Messages 221 Points 28 Location chennai Oct 12, 2017 #6 Kannan said: Which power amp are you planning to use with it? Click to expand... I want to try with lm3886 chip amp. Later I will try with le monstre. Thanks Badri
B badrisuper Active Member Joined May 24, 2011 Messages 221 Points 28 Location chennai Oct 12, 2017 #7 raj12345 said: But its looking quite cheap build. Click to expand... It looks stock and simple. Though showing it's age it sounds real good. Thanks Badri M
B badrisuper Active Member Joined May 24, 2011 Messages 221 Points 28 Location chennai Oct 14, 2017 #8 Has anyone tried pairing a chip amp as power and tube pre amp? Thanks Badri M
