I have already suggested some additional tests which might help convince him. A negative test where making the listeners think the cable has changed while not changing them for reasonable number of times and confirming the listeners are able to sense the cable has not changed.
Just to clarify, I did not question his intent or his integrity. I think I had put the "PS" there which lot of people missed reading. Please don't bring emotions into the picture. The statement was put to counter Captain's claims of there being unknown parameters and the intent of the statement was this - having studied about and seeing ethernet in use in my everyday life, I know how credilble and accurate it is. If it still is an unknown parameter, according to captain, as I do not have access to the experimental setup, how can Bhagwan's hearing, whose credibility (of his hearing and not of Bhagwan) is unknown, can be taken upon his word by other FMs who just know him in this forum to disprove my claims. I think thats a very logical call and I still hold on to what I said. Since you are not "questioning Bhagwan's hearing", may I know whats the basis of your confidence in him?
Science always works on reliable proofs and doubting another man's work is healthy practice and is encouraged. If not, we would still be living in a flat world where lightning and thunder would be attriubted to god's vengeance. Its as simple as this, if a person who doesn't know how to add comes and tells me 2+2=5 because his expensive calculator says so, I would not still believe him, because of what I know. I would still speculate that he may have pressed the wrong button in the calculator and explain probable causes of error. That does not mean I don't respect him or have a hidden agenda against him.
Sir,
I was not keen to get into this - maybe I did not want to make it get 'personal'
However, there are some basic things I want to state here;
a]
This Test was done for my personal understanding - it is not binding on any other person
b]
The People that did the test - with me are 'respected audiophiles' [in my book] - I hold their hearing in 'high regard'
c]
They [the people whose services I called upon] may not be known to you or to any other FM - if does not matter.  It was / is important to me what they have to say - when they listen & pass a judgement.
d]
Doing Blind Test / Double Blind Test / Reverse Blind Test etc. etc. All this was done by me / us 1 + decade back - at the end of the day - what are we trying to do ?  When we listen [with the number of years of listening] we do not need 'time' to know what is going on [sorry - this is my 1st 'bold' statement - do pardon me for saying this] - in 20 seconds; We go through 50 [almost 100 + sometimes] rooms of audio in it [gear that costs 250/-K US $'s ++] and we cannot do this blind / double blind / reverse blind test etc.
Either the system is 'singing' or it is 'not' !
e]
If 'we' found the cables to sound different - they do sound different - to us at least & that is all that matters.
f]
How many FM can sit in a room & listen to a set up & tell me / others or to them selves what is going on ?  Can they even find a phantom centre ? Intensity of that Phantom Centre ? Height of the sound stage ? Height of the Cello viz - a - viz a Violin ? Space between the 1st violin & the 2nd violin ? Front to rear spacing ? Distance between the Violin Section & the Tympani ?  Is the Wind Section playing from the far right corner in the back - neighbors house ?
g]
Technically, you think I DO NOT Know that CAT 5 / Cat 6 / Cat 7 / Cat 7 +
should not make a difference in the sound ? I very well know what the facts are [as per the book] The problem is that there is a 'difference' & therefore all this 'fuss' !!
h]
95 % + people that have voted here - do not think what I am doing has any merit & that is 100 % OK with me.  No issue.  I can live with that.
i]
I just want peole to 'listen' & then decide.  The problem is - even if you listen - you may or  may not be in a position to decide.  Silly Example I will give - we all drive a car - I assume & if in 2 different drives - same car - same road - I change the Tyre Pressure by 3 to 5 PSI will most of us know ?  There has been a change in handling ?  I will surely not know.  But, some persons are just sensitive to these things.
Does that make us 'bad' drivers ?  No, just that some persons are 'better' at this that others - simple & we have to accept that.
Same is about listening to music - we can all listen to music & appreciate it - most can tell a difference & some cannot & those who can - are also at different stages in their listing ability - we have to understand & accept this...
How many of you while listening to a Tabla Solo [Madar CD - ECM Records - Track # 6 - Jaw] can tell [even if to themselves] that with different cables the Table 'height' on the platform is altering ?  The Relationship of the Chata [Tabla]  & the Duggi - space between them - what height plain are they playing in etc. etc.  I could go on & on with examples & I will only more misunderstood;  Gentlemen get humble & try to learn - rather than trying to impose - you will walk away 'wiser' & 'content' [your music will be more enjoyed by you] !
j]
Just to 'refute' the calculator example - all Calculators will show 2 + 2 = 4 & not 5 - but they will have different Fonts / Different Size Fonts / Some will show with no 'zero' in their answer & some will show them as 4.00[or some other version] - same answer - different 'representation' - depends how you want to look at it...Same with ATM Machines - Cash will always be the same - just different combination of notes / new & old notes etc.  That will be the 'mix' [change in sound] - Data can never get changed [amount of money] but the way it is represented will alter;
I could go on and on - trying to 'defend'
But that will serve no purpose - I did this for a very different intent - obviously no one on this Forum 'got' what I was trying to do / say - so I suppose my experiment was a 'success' for me - it has failed in its larger objective;
I request MODS to CLOSE this thread.
Shall appreciate.
p.s. My Test are still on - as we speak - still have people scheduled to come - they will only come after eid - so next week - my search goes on.
