Cheap amplifier to get started with DIY
For a budget of 5 to 6k, he will have to use tpa3118 boards or an Allo.com digital amp board. Both, the V4H and DD will be way beyond in cost. Their trafos alone will cost 3k !!
Thats the best way for a beginner , you will get boards with built in volume and even bass treble controls for 500 , add a laptop supply and a box . And one usb dac board around 1000 bucks . For around two to three thousand it's a good start . Going for allo will be even better good sounding boards in very good price
I strongly second the recommendations for PeeCeeBee V4 (50W) or V4H (150W) or Discrete Dynamics 75 or 120W amps.
Get yourself the Discrete Dynamics preamp PAM12 to drive any of the above power amp options.
You'll end up with very good sound with any of the above combo. Don't go for some cheap amp as you'll soon want to upgrade it anyway.
I've tried, but have not found any links on where and how to buy DD pre and power amp modules as well as cost etc. One only comes across good reviews.
Please can someone put up some links to look up cost etc
Trying to get hands on with audio. Looking for a cheap amplifier (cheap as in ~ INR 5-8K) to experiment with some full-range drivers and 2-way builds. It is okay if it is not branded but would prefer something encased with proper connectors as against raw boards.
If sound signature is really an option in this price range, warm would be the preference.
Thanks! :)
Which city are you based in?
