compatible 16 gb microSD for sansa clip+
s_sachin
Hyderabad
Can someone be kind enough to point me to a ebay.in 16 GB micro SD card lthat worked for their clip. Reading a number of not compatible threads in google, wanted to be sure this will work.
thanks
Sachin
a class 2 would work just fine.. sachin.. no need to spend more for higher class as for accessing music only files class 2 would suffice.
Never ever use a class 2 card in Sansa Clip+. I had the exact same setup and it was atrocious. Because every time you connect the player to the computer, load it up with music and disconnect it, it will go through each and every file and read the metadata. And to do that on 16GB class 2 card takes a long time. I mean really long. If I remember correctly, it used to be about 30 mins.
So if you can afford it, buy the class 6 or class 10 cards.
