Creek Amplification!
Decibel
Chennai
The Creek Amplification!
[IMG2]http://img841.imageshack.us/img841/6677/creek5350.jpg[/IMG2]The Evolution 5350 integrated amplifier has been designed to fill the gap left by the Classic range, between the entry level Evolution 2 and the top of the range Destiny. It has borrowed technology from both the Evolution 2 and Classic 5350SE and is styled to match the EVOLUTION 2 CD Player and EVOLUTION Tuner. Each of the two amplifiers have been built indepedantly using high quality surface mounted components.
The power amp topology includes a cascoded differential voltage amplifier and MOS-FET current drive stage feeding a double Darlington output stage with four high-current bi-polar transistors to produce a very powerful amplifier capable of driving the most demanding of loads, with high resolution and accuracy. DC stability is maintained by a servo amplifier that rejects DC and allows the amplifier to be coupled directly without capacitors.
To enable 2 x 200 Watts into 4 Ohms to be produced from a small case, Creek has developed a massive power supply using a high grade 350 Watt toroidal mains transformer that powers left and right power amp channels separately, plus pre-amp and digital circuits. To keep the power amps operating safely, they are monitored by discrete transistor circuitry to protect against over-current demand, short circuits, over-temperature and DC offsets. Relays mute the input and separate the loudspeaker outputs in case of faults.
The 5350 retails for 104757 at current exchange rates.
Guys, it is 120x2 watts at 8 ohms, and 2x200 at 5 ohms.
And the 5350 uses differential voltage amplifier with Mos-Fets feeding high current bi-polar transistors. This does not need as much raw power as a Class A would need. In addition there are large capacitors to feed the amplifier stage plus enough protection built in to handle overloads, if any.
