Purna,
In my case too, removing the bathroom was a very hard decision but i was able to do so because my passion level was extra ordinarily high. It took me a several days thinking to take such a hard step and fortunately i am very happy with the call taken.
Indeed you are right that recliners and many others things should be bought at a later date especially if one is doing up a dedicated entertainment room.
About lighting, please continue to
toy with the great idea of having only those lights which are dimmer types or if the need be in-direct colored lights.
In my case the a/c is just behind the projector so servicing either of them becomes in-convenient but when i had the projector lift this problem was not there. The other thing is that my recliner is only a feet away from a/c so sometimes with some silent movie scenes the a/c noise distracts a little but if the a/c would have been somewhere in center of the room's side wall then this or other issues would have not surfaced.
It is wise that you are going for split a/c instead of cassette type due to your budget issues. In my case i went way above over budget, which was wrong but i have recovered all my monies as i am using my Mini Theater extensively since 5 years.
In-fact i know of at least 2 cases where they have spent big money on making theatre but they rarely use the room other then the initial euphoria though they continue to see movies very regularly but sadly above 75% of them in multiplex, television, I-pad, hotel rooms, etc. The point is one should never make a good planned entertainment room until they are sure that they will ban themselves going to a theatre by at least 75% and a big No via I-pad etc.
Further i have a friend who wanted to make a theatre in his duplex flat but since i knew that he rarely sees any movies, i discouraged him big time because it was not a wise step by any standard.
V.
Thanks Vinay. If i had considered this bedroom will be modified into HT room, would not have made Bathroom & Dressing section which would have given me 25 ft long room. After seeing your theater and how you had removed the bathroom for getting the length, i had also thought about doing it. But due to other factors like on this floor there will be no other water source, stopped thinking about it.
Also decided to go ahead with ceiling mount for projector. Need to decide on lighting and was thinking in similar lines. Thinking of recliners may be manual at later stage after completion of everything else.
From the interior perspective cassette air conditioner will look more elegant than split air conditioner and planned to replace the Fan with this. Though initially wanted to go with cassette, at the moment planning to purchase split due to budgeting issues. Does placing split directly above the projector screen will cause any issues to movie viewing experience? My guess is that it should not be an issue, since mostly room will be in dark while watching.
