Definitive Technology - ProSub 60
gr_babu
HI GUYS THIS IS BABU FROM CHENNAI
I HAD DECIDED TO GO FOR POLK PSW110 SUB (ROOM SIZE 12*12)
WHEN I CAME ACROSS A SPRASINGLY USED Definitive Technology - ProSub 60.
FOR RS 10,000.
I AM CONFUSED, PLZZ HELP ME TO DECIDE WHICH SUB TO GO FOR
POLK IS 10 INCH NEW SUB FOR RS 12500.
efinitive Technology - ProSub 60 IS A 8 INCH USED BUT IN A VERY GOOD CONDITION AS IF A NEW ONE .
PLZZ SUGGEST.
Go for Def Tec Sub as this is a specialist company for Subs and Cinema Speakers, Polk entry level Subs are just so so but when you have an opportunity with a Sub like Def Tech. then definetely grab it and I am sure that you won't repent it.
thx for the reply
i have gone forward and taken the def tech prosub 60
thx for helping me to take the decision
thx once again
