hello,
thought i would share my experience with making cables for my parent's HT. Cable quality is probably not as important nor that negligible for power or AV signal quality. I chose to tread somewhere in between.
using shielded coax cables i made line level interconnects with RCA connectors between my receiver and powered speakers/active sub.
these are the low frequency line level inputs left, right and subwoofer going into the sub. those are the decent quality rca connectors (approx. Rs.45 each) from MX Inc. India. The cables are Falcon premium OFC cables (India) sheilded coax with dual cores for a stereo usage (they are popular for noise-free commercial microphone cables). see the red and blue in the centre and aluminum shroud which is the common or ground for both. since this is a single channel configuration i used both red and blue.
as for my video interconnects i used one composite cable and Y/Pb/Pr cables from my DVD player to my projector.
And the connections inside.
the cables for the 3 component bunch are regular RG-6 coax cables (Rs.11/m) running close to 30ft without any loss in quality or distortion. those connectors are Monster Cable "type" rca connectors also manufactured by MX India. I used some insulation tape and some heat shrink tubing to get the connectors fit nice and snug. And for the composite cable i use for television the cable is RG-59 (Rs.6/m) and the connectors are the same as the audio interconnects.
I have been using these cables for 3 and 1/2 years with no problems and good quality. i Have pitched them against cheap rca cables and expensive Monster/Audionexus cables. while cheap cables are garbage, the only place where i felt my cables came short was the LFE cable from audio nexus had a negligible edge over mine in terms of bass from the subwoofer. The video cables seemed perfect!
These supplies or their close matches can be found in the electrical/electronics market of your city/town. Of course you'll need the basic tools - solder iron,lead,flux/ pliers or wire stripper/ mini screwdrivers etc.
many more DiY digital, toslink, speaker wire, D-SUB cables that i have made. let me know if anyone needs any info on them.
Kudos to Anil for initiatives on the DiY posts.
Cheers.
Cheers.
