DIY :Pass F5 Turbo V2 Joshua & Ali's Documented Build
Joshua's dropped of the boards today so i can tap the spreader and baseplate
Stunningly neat and accurate job i must say
im sure this took a lot of work
New cab shows 6 heatsinks and and extended size
the trafo is one really heavy boy
How tall are those sinks ? I have 4 the same but they are 11.8" high
mine are 7.5 inches tall each
thats why i took 6
with 11 inches you can do it in 4 pcs
sangram in kolkatta runs an almost fully biased F5 turbo with 11 inches ( 4 nos )
Thanks, thats great I need to try and figure our how to get a copper bar across my sinks like this too. That will really help with heat transfer. For now my heat-sinks are cooling my Hiraga 20w :D
I think I need to find metal bars like you found too, to put it all together.
was thinking of having them stacked high and making active speakers.
A crazy idea ? lol
thanks for the info!
