Friends,
as said in other thread I have a Jelco Tonearm. So started thinking about building a turntable around it. Will I make it or not is difficult to tell due to work pressure and few commitments. But posting some ideas which may help others or atleast spark their imagination. Feel free to comment or criticize if I go overboard or idea is just plain silly.
Ideally I was wondering if solid one block of metal would be a good base to setup a turntable on as it being heavy and least resonant. But it is not practical. So here goes...
Tonearm Base : Tonearm base would be solid metal cylinder with cavity to fix tonearms. This will reside in sidepanel like Thorens TD124. the panel will have phonostage etc. electronics inside.
Platter Shaft : Salvaged from good vintage turntable as I guess this being most important part engineering would be difficult.
Motor Base : Totally isolated base OR Motor will be well damped and hidden below the platter and will serve as a third feet (2 feet being in front). Not sure about this.
Platter : Ideally would like something as shown in following pic. This platter (Patent pending :lol only touches record label part and circumference of the record, so less area contact will result in to less resonance and vibration energy transferred to the cartridge. This will also insure that non playing music part of the record will not touch the platter. Will need center weight to press record on the platter.
cross section of the platter :
Platter at the top edge is slanted inside to make it stable. Record lable part and circumference of the platter will have some kind of rubber mat to dampen it further.
Motor : Good quality DC motor (Just to have different speeds) with speed regulation circuits.
Plinth : Hollow Wood plinth with compartments filled with fine sand or other damping material as I have read at some place that sand absorbs vibration and resonance and transfers in to heat.
More as I think.
More as I think.
