sanjivnayak
You can pair schiit magni 3+ with sundara.
I can understand your confusion. This arises when you spend more time reading reviews and opinions of others than personally trying them out. (I know that it is not feasible in the current situation). When it comes to music, there are a lot of subjective parameters and personal preferences. The music you listen to, the attributes that you prioritise and the ones you are willing to trade off (ex, harmonics, tonality, detail, soundstage, imaging, transparency, etc.), the budget, the paring equipment. With headphones/speakers this is more critical and you have to try it. There is no other way around.This is getting really complicated.
An HD600 costs as much as HD660S, and is an 18 year old model, and is the preferred model in the HD6xx series. Sigh!
Now I am totally confused.
Its understandable. 660 also is a higher number than 600 which compels one to believe it ought to be better. And how could a 18 year old driver better be a newly designed driver of 660. Think Gillette! In a boardroom, when they figured that they had given the men in the world the best double edged stainless steel razors and every man had one, and the money was in repeat customers but not for blades but for razors. So they designed and launched and marketed the disposable use and throw razors, a market that didn't exist. And then got us into twin blade, triple blade, 5 blades for a closer shave just to keep us chasing a rainbow when all you needed is one good blade in one good razor which was already there in the 50s. Look man..600/650 were once flagship for Sennheiser and 600 were the go to choice for every other audiophile, audio engineers for mixing. And then 700 came along and then 800 and then they took the drivers of 700 and put in 600 shell and tuned it to call it 660. I have owned 660 as well. Millions have owned the 600 series not due to hype. Get them, hear them and figure out whether they are your type of sound or not. If not, what would you like to change. They are very good in helping you with having a baseline of what good sound is all about and you can either call it end game or pursue your headphone journey. Very good and balanced starting point mate!This is getting really complicated.
It's good that you are trying different headphones. Audition as many as you can get hold of; regardless of budget, type, reviews. You will find the one that clicks for you. Ideally you should have the amp you use but I can understand if that is not feasible.So, I am in NYC trying out different headphones.
Today I tried out Hifiman Sundara, Beyer 1990, 1770, HD 660S. None of them floated my boat.
Finally I tried the Focal Clear MG (a new version of Clear), loved it.
Tomorrow I will try Focal Clear vs HD 800s
www.audiosciencereview.com
I really wanted to, but even though they are manufactured in NYC-ish area, it was not possible to audition them. They have no actual dealers.@essrand you should really try the zmf auteurs.
(I would have to buy, it would be shipped, then with a 14-day return policy, then ship back for refund if it didn't work, BAH! who has the time).
to echo what @fLUX is saying, I also have a pair of auteurs. the US price is generally killer and I would consider grabbing it. If you don't like it it should be pretty easy to sell here because there's a fair amount of demand and the INR landed price is naturally higher.I really wanted to, but even though they are manufactured in NYC-ish area, it was not possible to audition them. They have no actual dealers.
I can say one thing, if you want no amp - simple setup headphones that can match the experience of an IEM with all the advantages of the headphones - FOCALS! I had the Stellia, I could drive them with anything, not at all picky about the source, yes most headphones would change signature when paired with amp and dac etc etc, but something high-end and non-fussy is a rarityTo put a conclusion on this search.
I bought the Focal Clear Mg, liked it better than even the Sennheiser HD800s.
So much for keeping the price to around 30-40K, leave alone 70K![]()
Have tried the Clears out of a DAP for 30 odd minutes, they needed lower volume than the campfire IEMI can say one thing, if you want no amp - simple setup headphones that can match the experience of an IEM with all the advantages of the headphones - FOCALS! I had the Stellia, I could drive them with anything, not at all picky about the source, yes most headphones would change signature when paired with amp and dac etc etc, but something high-end and non-fussy is a rarity![]()
You will get sound, if that's what you are asking. But you won't be anywhere close to realising their potentialWould the Auteur work directly with an iPhone?
In that case I might be tempted to try rider and try.
I have 30 day return on the Focals![]()
Yup very efficient and very enjoyable, I could use stellia with my ZuneHave tried the Clears out of a DAP for 30 odd minutes, they needed lower volume than the campfire IEM![]()
