Going with Polk/Denon , need final suggestions
coolraghav
Delhi
Here's what Ive planned...
Denon AVR 1911
Polk Audio TSI 200 : 15K
Center CS10 : 9600
Woofer PSW 110 - 13000
Surround Tsi 100 - 11000
More of Music (which can be multichannel also) & TataSky then comes Movies.
If there's anything else you guys wanna suggest under this budget, please tell me. I'm looking for loud sound thtsy preferred polk over diamond 9.1.
I cant go more than this budget, but ofcourse ready to go lower if it wont make a difference.
Thanks guys ! waiting for reply.
If space permits go for TSI 300 FS instead of bookshelves...will be better for Music
Also PSW110 is quoted 13000/- psw 125 is 18500/- [profx website]
the system is worth every peny spend in this budget.
I have been auditioning the Polk series i find it best in this budget and also to my ears :)
there's no hardware difference except they are floor standers and these are bookshelves right ? (wattage n ohms r same)
space is problem coz I have this wooden panel being made. So I would be preferring bookshelves.
I pmd you also, are the prices okay ?
Thanks again
Looks like a real good combo, would suggest to go for TSi 300 for front surround, Denon would pair with Polk very well.
Please abandon your project.
You will be hunting for more within a year and would likely put your speakers for sale in this forum. Build your system slowly in steps.
As of now,since you are interested more in music your AVR choice is good. Buy Polk Rti A7/MS aviano 6 pairs and later after an year or more get a good sub.
Denon AVR 1911
Center CS10 : 9600
Hey buddy, did you already get those, if not try to get a better sub, which you can always retain over the years, paying atleast 10k more will get you better subs. Polk 110 does not do justice i have heard that.
Hello Coolraghav
Have you bought the system, if not why don't you consider RTi A1s instead of TSis. I have them for the past 2 years along with SW 110. Work great with Denon for movies and music (may be not as great as a dedicated stereo setup). You may have to stretch your budget a little but worth giving a try after auditioning both
Be Cool!
Here's another suggestion. If you are untreated in music more over HD broadcast or movies, get an entry level HTiB :either Onkyo 3400 or Denon 1312xp and use a GOOD pair of floor standers with the same AVR as alternate for music, ie disconnect FR and FL for music use from AVR and connect the Floorstanders in place. Using banana plugs would help you a lot in such a jig.
Sent from my Nexus S using Tapatalk
