Good Bluetooth Rx Tx
pushkarajd
Hi All,
I recently purchased Sony WH-1000XM2 bluetooth headphones. I am now in hunt for a decent bluetooth transmitter. It should fulfill the below requirements:
1. It should support aptX.
2. It should support 2 simultaneous device connections i.e. 1 bluetooth transmitter should support audio to 2 headphones simultaneously.
3. Good bluetooth range and should have a reliable and robust connection.
I am looking at something similar to Avantree Priva III but that is currently out of my budget. My max budget is Rs.1000-Rs.1200
Kindly suggest.
Pushkaraj
I recently did a whole lot of searching and finally settled for the Fiio BTR-1 as I needed something with battery life and 2 connections was not something I needed. In all the searching that I did, I dont think anything is available with conditions 1 and 2 at your price point.
The closest in price I found is on Amazon US store if you can have someone get it for you
https://www.amazon.com/TROND-Blueto...1340&sr=8-14&keywords=aptx+bluetooth+receiver
