Help me choose a Good Sub for Music
fran_elite
Can anybody recommend a good musical Sub for Stereo use.
I can stretch my budget till Rs 70K .
Speakers are Polk Audio RTi A3/Pioneer Stero Amp A5 -80's model
Thanks in advance.
Francis
Thanks in advance.
Francis
While I can recommend good musical subs, when I see other components in yoru system, I would say to get a 8 inch sub to pair with it since you wont see that big a difference in quality. Musical subs pair well with speakers that are made for music than HT and the polks in your possession are unfortunately that. A small trick in getting better performance for music is to close the vent in the sub with a sponge or tightly rolled cloth so the bottom end does not stretch out.
Thanks 4 the advice.
Do you think the LSi9 from Polk are good 4 music? Which Sub will blend well with the LSi9?
Any suggestions regarding Paradigm's DSP 3200 and 3400?
Let me know.
Thanks again.
Francis
i agree with marsilians. a sub at that budget will be an overkill. if i were you i'd take the 70k budget, sell the current components and buy a full new system. perhaps monitor audio silvers bookshelves, a nad / cambridge / marantz amp and a perhaps a small sub to go with it.
Just happened that i bought a used (almost new) Mordaunt Short 309i to compliment my Mission M32i bookshelves. Amp is NAD 355bee with pre-out. May be, yet to fine tune the setup, but so far the performance of the sub is very good for music (mine is just a music 2ch setup), not boomy, crisp and tight. In the course of time, it will become even better. Just giving my opinion as i am not sure whether it will go with your speakers etc.,
rgds swami
