reynoldmaben
Dear Friends,
I own a Sansui P900 TT which I purchased from a forum member. This TT came with a Audio Technika T4P cart (p-mount cart). While I was dusting the TT one day I happen to damage the needle and athe needle fell off the stylus. Upon checking with an expert, was given to understand that the needle can be stuck with a rubber based adshesive back to its place and it really worked well. Until one day I realsied that only one speaker was working and the other was very feable to hear.
I gave the TT to a friend of mine who is familiar with TT operations, when he checked he figured out that there was one part that was broken inside the cart due to which only one speaker was working and the stylus was fine.
So I purchased another cart Shure M92E (which is also a p- mount cart) to replace the Audio Technika T4P cart. Can anyone tell me if this would be as easy as just plug in and play or do i need to take anything else into consideration.
Appreciate you replies.
Reynold
Reynold
