Hello Vinylheads,
I need some help in setting up my TT.
1. How to set VTA on Project arm?
The project arm has a white line and i have set the vta in reference to
that white line on both ends. Is it the right method?
2. What is the ideal resonant frequency and how you calculate that with
the help of HFN Test Record without any apparatus?
My arm cart resonant frequency is 9.81 (calculated with the help of a
calculator on vinylengine.com). Is it good enough or should i look for more
or maybe less?
3. Do manufacturer take into account the weight of finger lift when they
specify the tonearm effective mass?
Currently i am doing without a finger lift. I am cueing with the help of arm
lift.
4. What i find all HOMC carts have output voltage to the maximum of 2.5mv
with a loading of 47kOhms whereas all MM's have an output voltage of 4-5
mv with the same loading (my Sumiko has output voltage 5mv).
Will i get less output if i go for these HOMC Carts?
Vasu
or maybe less?
lift.
Vasu
