HiMedia OWNERSHIP THREAD
Re: HiMedia HD600B or WD TV LIVE in India Pune
Received my Himedia 600b with wifi on saturday and I had some time with the player today. The player is very cute with a nice aluminum body and VFD. I bought a 1TB WD green series HDD also. Installation of HDD was very easy. You will need to format the drive for the player to recognize it correctly. I used the format option of the player as I don't have spare SATA cable or USB 3.0 cable to connect to PC.
The firmware version was 1.0.3.4 and I upgraded it to version 1.0.4.12. Upgrading firmware is also very easy and if something goes wrong, you can always recover your player. The upgradation took just 2 or 3 minutes.
As I don't have a wifi router at home, I used a software 'connectify' to create a virtual wifi hotspot on my laptop. However it resulted in BSOD so I uninstalled it. Then I used another software mhotspot which worked correctly. The player recognized the created hotspot and I was able to access network after entering the encryption password. Using my gprs connection I tested some internet media services like yahoo whether, some radio news channel etc. I was able to access youtube, but couldn't play files due to the super speed gprs connection. I also played an 1080p 4GB brrip from my laptop over wifi without any stutter. However copying files over wifi is a pain in the neck. I am yet to transfer my media collection to the disk for want of SATA cable or USB 3.0 cable.
Features like BT, Samba etc. are to be tested which I doubt I will never use.
In windows 7, this player becomes visible as a media player. This feature allows you to right click any media file in your pc/laptop and play it using hd600b. For this you will need to enable media streaming in windows 7. However I couldn't play files from windows 7. If anybody got it played please post how you did it.
Under network connections, the player appears with the name 'VENUS'. However I couldn't access it using the username 'root' and password 'hdpfans'.
For mp3, features like lyrics view, display of embedded album art in mp3 tag etc. are absent. Also, the genre view of songs was wrong. There is no way to split multiple artists also.
After a few hours of use, the body gets warm which is acceptable.
Overall this player is a great performer and I will recommend it to those who are looking for a good media player.
I bought the HD600B yesterday from Detna. I already have a 2TB WD green series HDD with almost 1.6TB full. Is there no other way other than format option to make the player recognize the HDD in the internal slot.
Try this. First connect the HDD to the external sata port using the bundled cable. Your hard disk should be visible now. Then try again with the internal slot.
What is the difference between 600B and 900B, the price difference is 2000 INR. I know that 900B supports 3D, so if you do not have 3D TV then is it same as 600B, are rest all features same? How abt the performance?
Yesterday i received my player and working fine. 900B is connected to yamaha amplifier with co-ax cable for audio out. I have played few movies stored on NAS. They are Ac3 movie files but i am not able to get any dolby sign on my yamaha amplifier. Is there any other settings to change it, i checked settings and Dolby option shows RAW.
Also Downloaded custom FW 1.1.10 cooked by OllyP, upgrading FW soon.
hi friends,
this is my 1st post, just yesterday i got my himedia hd900b from detna. i was very impressed by mr raghu of detna, he is very quick in his responses. about 900b, it played audio/video well
hi guys, can anyone pls confirm that hd900b does play back Dolby Ture HD and DTS HD MA along with normal dolby and dts 5.1 output with HDMI 1.4
hello ! just got my 900B delivered. kudos to mr. raghu ! and thanks to kittu, sushant, sukhjit, blasto and more ! all-in-all, thanks to HFV :p
now need to work with the product :)
Congrats! forget finding shortcomings and start enjoying movies as many as you can. (Legally ofcourse) :p;)
I completed my order today and got it shipped, mr raghu really helpful and responsive all the time.
one question pls: what current firmware it is having ? did you upgrade ?
and pls share ur experiences :)
congrats ! firmware in the box is v1.0.0.26. latest version (v1.0.1.9), as well as custom firmware can be found at the following page :
Firmware
i have even read some people using xtreamer prodigy's firmware on the 900B successfully.
am yet to upgrade the firmware. doing it now :)
Before you upgrade the firmware first find out what all features perfectly work with stock firmware. So you know which one to revert back...:)
its awfully slow ! people are complaining about the slow download speeds. one guy says he regrets getting the 900B due to this issue :p
should i download OllyP's custom FW instead from multiupload ?
