Hi All,
After reading through a lot of posts and my recent visits to blu ray stores in my city, i felt there is a need to create awareness on the usefulness of a region C player in India.
As I have seen in the shops (and from my own collection on Blu rays), over 90% of the disks are region free (Region ABC). Therefore these can be played in any region locked blu ray player. Moreover, nowadays all the companies are releasing only region free disks in India.
Now considering the above fact, I felt it always makes sense to buy a Region A player whenever one is considering blu-ray player purchase in India. The reasons is...
a. You can play all region A discs (imported at a cheaper rate from online websites, or physically from US)
b. You can play almost all Indian blu rays (I am yet to find one disk in India which is Region C locked, but there might be few) which are region free.
On the other hand, a region C player will
a. Restrict you to play disks available only in India which are anyways region free.
b.The costs of blu-ray players are also higher than other countries ( I know its coming down but still for a comparable model its much higher). For instance, an entry level Panasonic 3d player BDT-110 is available in India for almost 18k, while a much advanced Panasonic BDT320 region A is available for 16k (though ebay.in). If you import it, the costs are even lower!
c. These players wont allow you to play cheaper imported blu-rays either (region a) which one can buy from online shops like Amazon etc.
d. In specific cases (like me), if you are lucky enough to find a blu-ray rental shop, you wont be able to rent half of the movies since those are in region A!
Now I might be completely wrong in my assumption here, but it would be good to know others opinion on this area. Otherwise, this thread might also help other in their purchase decisions.
Cheers!
Cheers!
