surinder1508
Guys my HT room dimension is 16'x12'x11'(LxWxH)
I'm looking forward for advice on what color scheme should I use in my HT room which can contribute to reduce unwanted ambient lighting n bounced light from the screen.
At present the ceiling is white
n the walls are darkish peach colored should I change colors of the room I mean it will take big effort to empty the room n then after coloring again re assemble all the things so if it worth then I can do all this effort.
